Subtract not working as expected
Hi! I'm playing around with the weight painting of suzanne and while the demonstrated version of just adding to the other vertex group with normalize on certainly works using the subtract brush (or holding CTRL while using the Add brush) does not work for me and I don't understand why. I would have expected the subtract brush (or the inverse of the add brush) to remove weight but it still just adds on weight. Would be thankful for any help or explanation of that behavior.
Reply
    What are your weight, and strength settings? If you don't have accumulate checked you will have to let go of the brush and stroke multiple times. Are you using a digital drawing tablet? Do you have pressure turned on and which items do you have it on for?
  • Wayne Dixon replied
    Solution
    Hi Julian,
    I'm pretty sure the Subtract operation is working correctly and what you are experiencing is Auto-Normalize doing its thing.
    The normalization will make all the groups add up to 1.0.  And if a vertex is only a member on 1 group, your brush will subtract it to a weight of zero, but then the auto-normalise will normalise it (back to 1.0).
    You will need to either disable auto-nomalize or have those verts be a member of more than 1 group.
    Hope that helps.
    3 loves
