I do not see the sheen or toon shader
posted to: Sheen and Toon
Hello, i'm sure I am overlooking something somewhere, but I do not see the sheen or toon BSDFs. I am running Blender 4.2.1.
They are just not there underneath of shaders after I press Shift-A in the shader editor. I even search 'sheen' and i get no results found.
Will it only work with a particular type of object? I am using a cube
Is there an add-on that needs to be turned on that I might have missed earlier in the course?
Thank you.
Reply
  • Ewa Wierbik-Ziąbka replied
    Solution
    Are you using Cycles? Both sheen and toon shaders are not available in Eevee. :)
    2 loves
  • Erik DiLauro(Scrappy_Bogart) replied
    Thank you! That was exactly it.
