When I add the IK constraint to the arm, and then the pole target, it moves a bit so it is no longer perfectly on top of the other counterparts. It looks like it rotates around 1,5°. At first I thought I'd made a mistake, but then I checked your Luna_rig file and found a similar thing happens there (but only 0.9°). Maybe it doesn't matter and it's OCD?
Maybe you mentioned something about this when going over IK in a previous course or exercise, but I have a memory like a goldfish!
Thanks, I was able to dial it in so they overlapped almost exactly by using the value 1.5°.
Hi Markus.
If the pole target is directly in-line with the leg chain and perfectly straight - you won't have any mode shifting (That's what I call it when the rig moves when you jump between edit mode and pose mode)
A lot of the time though, there will be a tiny bit of shift when the leg is at an outward slope (like it is in Luna).
If it's a small shift, don't worry about it, but if it's a large jump, you can adjust the pole vector angle to reduce it.
Hope that makes sense.
