Supplemental - Texture settings for stencils
講座動画の通りに作業してもステンシルの結果が同じになりませんでした。
The stencil results were not the same when working as in the course video.
いろいろ試してみたところ、下の画像のように設定することで、講座動画と同じ結果にできました。
After trying various settings, I was able to achieve the same results as in the course video by setting up the image below.
※試行錯誤の過程で画像の白と黒を反転していたので、元の画像を使用している場合は「Invert」もオンにする必要があると思われます。
*In the process of trial and error, the black and white of the image was inverted, so if you are using the original image, you will probably need to turn "Invert" on as well.
調査の過程で学びになったことがあったとはいえ、ただでさえ苦手なテクスチャリングで、動画通りにやってもうまくいかないところがあると、講座を続けることが辛くなってしまいます。
Even though I learned something in the research process, it is hard to continue with the course when there are parts of the texturing that I am just not good at, and even if I follow the video, I still can't get it right.
もし同じ問題で困っている方がいましたら、この情報が役に立つと嬉しいです。
If anyone else is having the same problem, I hope this information is helpful.
*Translated using DeepL.
5 loves
Reply
  • Omar Domenech replied
    Hello Noritaka. That's ok, we're never good at something at first, remember as we always say, it's practice, practice and practice. You'll get the hang of texturing in no time as you continue to do it more and more, so just keep at it. Churchill said “Success is the ability to go from failure to failure without losing your enthusiasm”.
