Portal
Why do you need HDRI if the area light covers the window?
2 loves
Reply
  • Sascha Feider(SFE-Viz) replied
    Base on the title of your question I'm guessing you're talking about an area light in front of a window which gets then marked as a portal?
    In that case the area light doesn't actually emit any light anymore. It works as a guide line so to speak to guide the light from the hdri through the window. It basically provides the render engine with a path to steer the light into the room more efficiently. You can reduce noise in interiors this way. Without the HDRI it would remain dark though.
    I think of it this like saying: Here Cycles, I've got this portal for you, this is where I want you to throw more light through. I hope that makes sense. :)
    3 loves
  • Omar Domenech replied
    I'm with Sascha, I'm guessing you mean why the area light becomes a portal. And it is exactly that, it helps to get mode light funneled through the opening and it helps to clear out the noise. It's one of those black magic hacks hat are super useful.
  • Adrian Bellworthy replied
    The answer has been graciously presented already, I believe Kaizen mentions it in the course too.
    To settle your curiosity when you have a question like this, it's a good idea to test it out.
    Remove the HDRi and see what happens.
    3 loves
