I have issues with the tinting os a specific layer. It doesn't want to be tinted, even though I selected it, the strokes and the material and locked everything else. it did change the color when tinted, but not in material mode but only in solid mode. The other layers don't have that issue.
Reply
  • Omar Domenech replied
    Hello Sheila. Private Investigator Paul will be on your case shortly. In the meantime, try attaching screenshots or other resources or information that could help him crack the case more easily. Fingerprints and DNA are no longer admissible evidence in court. Something about faulty procedures, we have been lied to all these years by detective TV shows. They also lied about romance and relationships, that's not how they look like in real life.
    2 loves
  • sheila5 replied
    Hi Omar, weird I didn't get a notification of your reply
    here I show my selection
    here I show that nothing happens in material preview mode
    unless it's in solid preview mode
    nothing happens in material preview when I try to color
    ps this is not my final drawing, I was just experimenting with the technique and then I stumbled upon this strange anomaly
    Okay simple question, are you set to color mode or material mode. Also if I remember correctly tint tool can be set to vertex paint mode or draw mode. Sorry I'm not at home to check this, but I think this might be where the problem is.
    ***edit*** These are options with the normal draw brush not the tint brush. The other thing is the vertex paint brush which works like the tint brush.
  • sheila5 replied
    I don't know because I can only see that in paint mode and not in tint mode. The other layers can be changed with the tint mode. could be that I set them up originally in a different mode but how to see that?
    The first thing I'd do is hide all the other grease pencil objects(Eye icon in outliner). Then hide all the other layers(Eye icons in the Layers panel). Then Hide all the  other materials(Eye icon in material slots box). Then see what you have. This will narrow it down to that layer, material, and object. If you still have the problem then it's within that layer or material. If it works fine then you can start turning things back to visible until you have the problem.
  • Paul Caggegi replied
    Hi Sheila, I would recommend doing this in Vertex Paint mode, because you also have selection tools there. Tint could have been set to stroke only; it might have deselected (although you cannot see) so it won't work; a few other things. In Vertex Paint mode, you have the option to select areas just like in edit mode
