Bevel doesn´t apply to edge
Hi!
Somehow on one of the edges, the bevel doesn´t work.
Reply
  • Omar Domenech replied
    Maybe it is double vertices? In edit mode select everything and M to merge by distance. It could also be the angle. Can you upload your file so we can take a look? You can use Dropbox or Google Drive and post the link.
  • Thomas Schachinger(apfelmus) replied
    No, I tried that before and there were no double vertices.
    Here is the file: https://www.dropbox.com/scl/fi/zfoa8vyfwxfl7j3cdpp3x/gameboy.blend?rlkey=qkm59kr0rv3ibtkt1mkv0smrp&st=22xxu5ze&dl=0
    I tried to move the whole edge loop along the y-axis for a little bit, that kind of worked now.
    It works for me to connect extra edges with the knife tool to the edge below:
    2 loves
    This works great. Thanks for your time and help!
  • Martin Bergwerf replied
    Hi Thomas,
    Link says: "Item was Deleted".
    Although Omar's method works, that shouldn't be necessary.
    We have seen before, that this was because there was an angle (red line) between 'top and bottom' Faces (can't see that from your screenshot...), something like this, maybe:
    Cheers Thomas!
    It was indeed as I suspected. It's rather subtle (hard to find, if you don't know what to look for 😉, but I created an extra Edge as a guide to see if there was an angle and behold:
    Moving these Vertices back in Y a bit, to 'meet' the helper Edge (from Side Orthographic View), gives the wanted Bevel:
    2 loves
    I see, that´s interesting.
    Learned something new again, thanks a lot Martin! :)
  • Jesus Chavarria(bacontaco) replied
    Kinda late, but if you remove the clamp overlap option in the bevel modifier, the edges should bevel without adding more cuts.
    Hi Jesus bbacontaco ,
    Kinda late...and also incorrect 😉
    As can be seen in the first screenshot, Clamp Overlap wasn't enabled and thus not causing the issue.
  • Cyril Ng(cyrilon99) replied
    Hi,
    I have encountered a similar but different issue, The highlighted edges weren't able to bevel by adjusting the bevel weight through transform. The ctrl+B works for all.
    While there doesn't seem like to be an angle between 'top and bottom' Faces like mentioned above.
    here's the link to the file: https://drive.google.com/file/d/1CmVRIAxvYAWT--DYZtE5hIFzY-_0A1SA/view
    thanks!
    Hi Cyril ccyrilon99 ,
    Without looking at your .blend file, I'd guess it is because of the Clamp Overlap in the Bevel Modifier.
    2 loves
    thanks Martin it worked
