Arm + Legs "stretch to" mch not working
Hello
Not sure what I did wrong, but when I followed along added a 'stretch-to' constraint to the DEF upper-arm, forearm, thigh, and shin, I didn't get the same result. The result I got was the same as when you just added the initial constraints to the forearm and shin, the whole arm/leg chain doesn't stretch.
3 loves
Reply
  • Wayne Dixon replied
    It looks like you just missed 1 thing, Steve.
    I held down ALT when I added the 0.1 stretching to the limbs.  That way the property was edited for all the selected bones at once.
    If you select both limb segments and then edit that setting, it will only apply the change to the active bone (the one you selected last)
    Hope that helps.
    I can see you've posted that file (which is how I discovered your issue) - but feel free to amend that submission before I officially grade it  ;)
    7 loves
  • jrdrmotwani replied
    Wow this was helpful! I had missed that too. Thanks for this question and the answer too :)
    2 loves
