Slider axis
Hello,
the Slider work only in X axis, but if the object in our scene need to move along the Y axis for example, how do you proceed ?
2 loves
Reply
  • Hugo Falarz(Ozen) replied
    Nevermind i think i found the answer, i used an empty and it worked :)
  • Martin Bergwerf replied
    Hi Hugo,
    That X-Axis is the Object's (Local) X-Axis, so you could also, for instance, use the Options > Transforms > Affect Only > Origins and Rotate the Objects Origin so, that its X-Axis is pointing in the direction you want to Slide it in:
    Hard to visualize this in one picture...hope it is still clear.
    2 loves
    Oh yes, it's easier this way thank you !
