• Paul Caggegi replied
    This appears as though the spotlight is not actually pointed to the plane of the bubble - remember this is a 2D object, not a sphere. Try angling the spotlight towards the plane of the bubble (I am assuming this is X-Z, so if you rotate the lamp along its X axis?) I prefer to use point lamps, as these will cast a radial glow that is not directional. Proximity to the Grease Pencil object, as well as intensity is what will give you the glow effect.
  • Marcel Hoekstra(Artmhdesign) replied
    Hi, Thanks Paul. Nothing worked unfortunately.. I tried spot, point and even sun light. I positioned the light straight above, in front (angled towards grease pencil object), but still no lights...
  • Martin Bergwerf replied
    Hi Marcel,
    Maybe try increasing the Light Power to something greater, like 3000 or so. In the case of a Sun Light, try 7, or even 10.
    set spot power to 10000. Move it -1M on the y axis. X location should be 0 and z location should be just above the bubble. You should now see where the spot light is hitting the plane.
    Just a dumb troubleshooting tip to check: your grease pencil object - do the layers you wish to light have "Lights" ticked?
    I'm also assuming you've created this bubble in the default orientation (X-Z) so if you're using a point lamp, try moving it along the Y axis (You can do this my hitting G-Key to grab, then Y to constrain movement to only the Y axis). If it is behind the GP Object, it won't show anything. If it is in front, usually when it is really close, this should show the light effect. Once you have a position, tinker with the intensity and further position until you get a result you like.
    Hi, guys, so many thanks for your help. Unfortunately nothing worked... :(. Is it ok for someone to take a look at the file? Thanks in advance!
    https://www.dropbox.com/scl/fi/zi2icimb4jvjdxhduhll8/Cgcookie-Bubble.blend?rlkey=a32gxb63ph2kqkk970a1e9k80&st=oop2i4qw&dl=0
    After looking at your file you have 2 problems. First, you need to check Grease Pencil use lights in the preference editor on object tab under visibility panel. Second on the Fills layer you need to check Lights.(Properties editor->Data/Grease pencil tab->Layers panel) Side note you also need to be in render shading mode(Z)
    2 loves
    Hi Dwayne, thanks! Great it works! I thought I had it all checked, but no. Super!
    Yeah that was a tough one. It also took me way to long to realize that use scene lights was not checked in material preview which is why I added the part about switching to render shading mode.
