Low Poly room camera issue
I am doing the low poly room exercise and my son did something while I was in the restroom and I cant get the camera back to how it was?
Reply
  • Martin Bergwerf replied
    Hi Chad,
    It's a good exercise to just move and rotate the Camera around until it looks like how it was (more or less). Looking through the Camera and enabling View > Lock Camera to View, can make that easier. (in 4.1, there is also a lock Icon, that you can use for that:
    (See next image)
    But, if you started from the given start file, open that file again, Select the Camera and then CTRL+C. Then switch to your room file and CTRL+V. that should paste the Camera right where it was in the start file. Then you can Delete your misplaced Camera.
  • Omar Domenech replied
    Yes I was thinking the same thing, just get the original camera back from the original file. You can also use File and Append, navigate the blend file and get your camera object back.
    I think, that if you Append the Camera, it comes in "neutral', without its original Location and Rotation.
