control J and F just ended up adding two straight lines
posted to: Explore the Toolbox
not sure why this is happening
Reply
  • Omar Domenech replied
    Control + J joins two objects together and sometimes since it has open ended end it closes them with the curves being set to cyclic, Paul will probably confirm. The F key does as you say, it connects two points with a straight line, if you want to have a closed up stroke that you can fill.
  • Paul Caggegi replied
    Hi Ben. You can find some trouble-shooting tips in this lesson: https://cgcookie.com/lessons/lesson-04-cleaning-up
