help please :)
As seen in the video, while you can fill in other spaces with the f shortcut, unfortunately it does not do the d pad part. Where could I be making a mistake?
  • Ahmet Yavuz(exipartion) replied
  • Omar Domenech replied
    You probably have double vertices there or a face on top of a face. So for starters, select everything that makes the D-Pad and M to merge by distance. If you want to troubleshoot that part better, you can also with X delete only faces and fill them one by one.
  • Martin Bergwerf replied
    Hi Ahmet, it looks like you have so-called 'double Vertices' (here: overlapping Faces).
    Exaggerated, something like this, maybe:
    Select everything (with 'A', not with Box Select!), or the whole D pad (with Transparent Mode/X-ray vision) and the M > Merge > By Distance.
    It's fixed, thank you for your help
    You can also just re-model the D-Pad from scratch.
    For instance: start with a Plane, Subdivide (Number of Cuts: 2), so you get:
    and then Delete those 4 corner Vertices.
