Face missing when in cycles render engine
Hi guys! I seem to have some faces missing when I change to the cycles engine and I don't know why. I tried filling them but it doesn't do anything. Can you help me out pls? Thank you!
https://drive.google.com/file/d/1nw4IgsNM0TZX8HvdK_2cJGMyr_HT-jZm/view?usp=sharing
Reply
  • Vue Thao(euv) replied
    Big help would be better if you upload a blend file on dropbox or google drive.
    It looks like you have double vertices. Try using merge by distance. (in edit mode, press A to select all. Then M->By distance)
  • Martin Bergwerf replied
    Yes  Christian CChristianDior ,
    As euv already said, a link to your .blend would be helpful here.
    2 loves
  • Adrian Bellworthy replied
    At the very least an image in edit mode so we can see the mesh.
  • Omar Domenech replied
    Those black strips are probably not missing faces, but overlapping faces, they tend to create such artifacts. Also flipped normals. Or maybe those faces don't have any material applied. So it could be a couple of things.
