weird shading at 6:40
posted to: Modeling Ducts
im getting some weird shading on the duct when I add the solidify modifier. I have normals turned on. I tried to select the faces and shade flat but nothing worked. is there something I'm doing wrong?
  • Ricardo Canales(rcanal1996) replied
    Update. I did notice I didn't delete the faces. it that took care of some of the problem as I still have issues with the even thickness. if I enable it , it gives weird shadowing to the duct but if I disable the even thickness it removes that shading.
  • Martin Bergwerf replied
    So, let me get this straight Ricardo, you solved it, right?
    Or do you still have a question?
    (It could be, that you have some so-called Double Vertices or so...)
  • Adrian Bellworthy replied
    Yeah it looks like an issue with the geometry in the corner of the duct, behind the toolbar in the images.
    Most likely double vertices.
  • Omar Domenech replied
    It can also be interior faces. That last black line of edges is more black and thick than the others, possibly meaning that there's a couple of faces bunched up there? It's definitely a mesh problem.
