Object disappears after I apply boolean modifier
Question Modeling
I was able to model the first dice fine, however as soon as I tried making the second one it started disappearing. My CPU and RAM were 100% loaded at the moment, maybe it is somehow connected.
Reply
  • Martin Bergwerf replied
    Sorry, that's too fast for me...
    There are  a bunch of things that can go wrong with Booleans...flipped Normals, holes inn Meshes, also try switching between Fast and Exact and look at the Advanced Options...
    2 loves
  • Omar Domenech replied
    Booleans are very finicky, sometimes the most tiny thing helps, like moving the cutter object up and down a bit, moving it a bit backward of forwards, try reducing the poly count and all those little things you can think of that can trigger the modifier to behave well. As Martin says, flipped normals, interior faces, duplicated vertices,  bad geometry overall, try fishing for all that stuff.
    2 loves
  • Y M(Absurditas) replied
    This setting seems to have fixed the issue, but loading time was brutal, had to wait like 7 min for it to calculate.
    Yes Booleans don't come cheap...although 7 minutes is extremely long 😱
    2 loves
