I cant join faces it gives weird outcome
something is wrong with joining speaker and the mesh
  • Nischal Choudhary(Nischal) replied
  • Omar Domenech replied
    Can you walk us through the issue with more detail. What is the weird outcome? Can you post other screenshots that undesired outcome more clearly, even better if you can post a screen grab video. One thing that could be happening is that you are trying to join and create faces on two separate meshes. You first need to join them with Control + J so they are part of the same object.
  • Martin Bergwerf replied
    Try the other options I gave you: make sure you don't have any extra Edges Selected and check for Double Vertices.
