diff unwrap
posted to: Cutting UV Seams
i got a little bit diff uv unwrap is this ok? or i just did any mistake.
  • muqaddas replied
    This is uv unwrap in the lesson
    And this is my uv unwrap like i got more pieces
  • Martin Bergwerf replied
    Your Unwrap looks totally fine, Muhammad.
  • Adrian Bellworthy replied
    It looks a perfectly good UV unwrap.
    If you added more seems then you will get more pieces, and your model may not be totally identical, in which case you should expect a different result.
  • Omar Domenech replied
    The only piece that is very different is the circle UV island for you is totally straight. If you did exactly the same and got totally different results, maybe your Blender version is unwrapping things differently, so you could try using the same Blender version as in the video to see if you can get the same results. Not very necessary but you could experiment.
  • muqaddas replied
    thank you so much everyone
    Honestly Its pleasure to be a part of your community everyone is soo nice :)
  • Chunck Trafagander replied
    Jumping in with the same response, but what you have is completely fine! Like was mentioned, depending on where you made seams or the version of Blender you have, it will likely unwrap slightly different. The main thing you will want to take a look at is that you are getting minimal stretching in your UVs, indicated by the blue colour. With what you've shown, I do not think you will have issue continuing along with the course. :)
