Texture bake a procedural material at 1K
Question
Hi,
I have made a procedural wood floor material. And ran into an issue when I texture baked a diffuse, roughness, and a normal map with the resolution 1024x1024. Here you can see the material:
  • Tom Fransson(tfsuper3d) replied
    And here were my render settings:
    I think the issue is something with the brick texture included in the material. And here is my diffuse bake result for just that one:
    The join lines across the board is not even in thickness. And here you can see how it looks like when I gave a floor material those three baked textures:
    and here is another example of the same floor where it looks abit strange:
    So if anyone has a solution to solve this problem I would be very grateful. Thank you
  • Martin Bergwerf replied
    Hi Tom tfsuper3d ,
    Nothing pops out to me from looking at your screenshots...
    I am doing some 'heavy Rendering' at the moment, so I can't really do much in Blender now, but if you want to upload your .blend and post a link here, I will have a look tomorrow (if someone else hasn't figured it out by then, of course).
  • Omar Domenech replied
    If you bake it at 2k or 4k, does the same problem occur?
    Hi Martin and Omar. Here is the link to it:
    https://drive.google.com/file/d/1mOLsYMbEt3-xUjiPUFTNJw57N_WXwXFK/view?usp=sharing
    Thanks Tom, I'll look at it first thing tomorrow.
    Could you also tell us what Blender Version you used for this, please?
    Thank you Martin. Blender version LTS 2.93
    • ๐Ÿ‘๐Ÿป
    Solution
    Hey Tom,
    I had a look at your file.
    The problem is, that your grooves are about 1 Pixel wide, when Baked in a 2K Texture:
    Which means they are about half a Pixel in a 1K Texture Bake. With some AA, that gives the result you got.
    Solution: use a 2K Texture, or scale your Procedural (using UV Coordinates, instead of Object Coordinates also does the trick).
    Hi Martin
    Your a star. I did what you said and used UV coordinates instead and also scaled the brick textureย  with the mapping node (0.5, 0.5, 0.5) before baking. And that did it, no issues with anti-aliasing. The grooves are even and look good, at 1K now. If I setup a floor material with my baked textures and scale them just as I want it still looks good.
    So thank you very much Martin!
    • ๐Ÿ‘๐Ÿป
    I'm glad it worked out, Tom!
    Some extra remarks:
    It is technically not Anti-Aliasing, bad choice of words from my side, but it's very similar.
    UV Coordinates also Scale the Texture, because they go from 0 to 1, whereas Object Coordinates go from -1 to 1.
