Learning through different versions of Blender?
Question
This isn't a question. Only a feedback
This course looks excellent, but unfortunately I'll give up on it due to the differences between the original version and Blender's current 4.01 version.
Kent suggested to follow the course using the original version (3.5?), but I prefer not to do that.
I'm a beginner and I don't want to learn a method of doing something only to find out later that that method no longer exists or has been widely changed.
Whenever possible, I suggest to add small video entries (or maybe discussion section footnotes) with the adjustments of new versions.
Thks
2 loves
Reply
  • Martin Bergwerf replied
    Solution
    Dear Alexandre sivasu ,
    Don't worry, the methods haven't changed.
    Especially for beginners it is recommended to use the Blender Version used in the Tutorial/Course (although that might sound unintuitive).
    You might also want to have a look at this fresh new Article: https://cgcookie.com/posts/top-7-tips-when-starting-to-learn-blender
    4 loves
  • Omar Domenech replied
    Nothing to worry about, there is no need to fear the Blender version, the software hardly ever changes in a meaningful way, workflows have stayed the same since forever, core knowledge is still always there. The thing that changes is just names and buttons placements in the UI, things learned are always 99% applicable.
    Specially if you are a beginner, it is the best of ideas to follow what's on screen with the Blender version used in the video, because it is easier to follow and everything you learn will be applicable no matter the Blender version. Updating courses and videos is practically impossible due to the speed in which Blender develops, everything everywhere becomes outdated the moment a new Blender version comes along, everything on YouTube and everything everywhere at the same time, no one can update things their entire library, it is unattainable. But it's just outdated in the sense of what's visibly on the screen, no more than that.
    3 loves
  • Adrian Bellworthy replied
    As above 👆☝️
    As a beginner your priority is 3D CG knowledge over Blender version.
    Once you have the 3D CG knowledge, Blender version is less relevant.
    As mentioned in the post Martin shared, the latest version is recommended for your own projects, but not necessary for learning the concepts.
    3 loves
  • Kent Trammell replied
    Solution
    Hi sivasu - Your perspective is understandable and quite common, especially early in one's CG / Blender journey. As a crew we've debated a lot through the years about the best approach to dealing with Blender versions in our courses. The discussion session is a good idea, which is why we have Q&A like this thread. Often students ask a question about a version difference and these 3 gentlemen (Adrian, Omar, Martin) answer quickly.
    But if a student follows every course with the Blender version used in the course, that eliminates a lot of need to ask questions. The reality is, while Blender updates frequently, the core methodology of computer graphics has remained essentially the same for the 20 years I've been doing it. Moving vertices around into models, laying out UVs, material parameters, simulation concepts, rendering characteristics...still the same.
    I find a lot of new users think Blender is drastically different, version to version. As if Blender 2.8 -> 4.1 is like SNES -> N64. Again, the difference between versions is far less significance than the release hype makes you think.
    I encourage you to look at Blender holistically. You're learning the underlying methodology of computer graphics, not merely how to use a certain version. A holistic understanding makes your skills transferrable between Blender versions and even 3D software entirely. And don't make the mistake of thinking previous Blender versions are obsolete. Treat each version like a chisel in a drawer of chisels. No carpenter has a single almighty chisel for every situation. They maintain a collection where each is useful in their own way.
    Consider this too: As a student learning Blender holistically, you can learn from countless courses and tutorials throughout the years! If you limit yourself to only learning the latest version, you restrict yourself to a handful of courses and tutorials before the next version releases. Then your problem starts all over again: New version of Blender with zero tutorials recorded for it.
    As every artists learns in time, developing a "blender-fluid" proficiency is the best - well - really the only way.
    10 loves
  • Alexandre Nobre(sivasu) replied
    Thank you for your advices Kent.
    2 loves
  • Yanni Fraga(yanni_f) replied
    I understand that updating all the courses isn't a realistic option, but even a very simple footnote, like Alexandre suggested, would be amazing in some cases :)
    yyanni_f for sure, footnotes can be a reasonable thing to implement. In fact I just got off a call with Bossman Wes about how updates like footnotes, addendums, and even re-recordings (in extreme cases) can be implemented. A key to doing this was hiring IA's like Adrian Bellworthy, Omar Domenech, Martin Bergwerf, and Phil Osterbauer. Together we'll be able to keep a pulse on the constant blender changes and how to best inform students about them.
    Still, while those will indeed be helpful, they will never be as helpful as the advice to embrace Blender version fluidity.
    4 loves
  • Borgelin replied
    The differences in versions can end up getting rather frustrating. I have now spent time trying to figure out:
    - what is the equivalent of Specular in the new BSDF
    - X for swapping colors does not work
    - Shift + K for flooding the color does not work
    I'm stuck atm until I figure out what the difference is or if this just doesn't work in 4.1. Instead of having fun, I'm just getting frustrated and want to go do something more productive as I feel I'm just wasting precious time (in the worst cases).
    I appreciate the tips, Kent, and approaching the holistic view when it comes to the software itself. But at the same time, in my opinion it's a good idea to learn the latest version as soon as possible:
    1. Because of improvements and new functionality, some times these are major.
    2. To keep oneself updated on the direction the software is moving, to stay on the "development-train" so to speak.
    EDIT:
    - After updating to 4.1.1 (newest), hitting X works again for switching colors
    - Keymap for flooding the primary color has been changed from Shift + K to Ctrl + X
    - The equivalent of the Specular-setting is the IOR (Index of Refraction) Level under the Specular sub-menu in the P-BSDF
    More info in this video for the new and improved Principled BSDF-node:
    https://www.youtube.com/watch?v=7ucxCoa7jq0&t=0s
    2 loves
    Borgelin I hope you don't mind me challenging your logic a bit more. Please understand it's not for the sake of arguing, but because what I'm trying to convey has huge consequences to your learning journey.
    Your two points for why you commit to the latest version are sound! Those same reasons are why I too opt for the latest version of Blender **so long as it doesn't cause issues with my projects/workflow**. Because, at the end of the day, I'm really only interested in created cool stuff regardless of the tools that I use. This is where we differ and where I believe you (and most Blender learners) choose to make your learning journey more difficult than it needs to be. This is what I'm trying to change for you and the broader community.
    The critical point to remember - the point that governs all of this logic - is that Blender only exists to make stuff within computer graphics. A properly prioritized list of a Blender learning journey looks like this:
    1. The artform: Computer Graphics
    2. The understanding: Learning Computer Graphics
    3. The tool: Blender (or any other 3D app)
    Deciding to use the latest version of Blender regardless of the version taught in a tutorial/course introduces software inconsistencies that are distracting, usually frustrating, and can motivate you to abandon the course. This perspective puts Blender at the top of your priority list at the expense of the other two. If you abandon the course due to Blender version in consistency, you're sacrificing learning and execution of skills in favor of the software version.
    This is backwards and the cost is significant. Think about how many courses and tutorials you cannot learn from if you're committed to only using the latest version. Then think about how few courses/tutorials are available for the latest version. The latter of which is repeatedly true with each new release.
    Is it really worth the (over)commitment and ignoring all prior blender version education?
    This is when learners are keen to call for course updates, which is totally understandable. However course updates are difficult and costly and instructors rarely do it as a result. But aside from that, more importantly, the learner has no control over if and when course updates occur. If you wait around for an update, again you're sacrificing the ability to learn relevant skills *now*. Using the version of Blender that matches an existing course means you have control to learn now.
    "But if I learn how to do something in 2.8, won't I have to relearn how to do it with 4.1 eventually?" Yes and it's way easier than you think! This is why it's important to realize how little CG has evolved over the decades and especially how little really changes with each new Blender version. Besides, EVERYONE has to get familiar with every new Blender release; we're all in the same boat in this way. So there's literally no avoiding the [minor] issue of learning to do stuff in a new version. Learning the real skills - the skills that transcend 3D software / version - that's the actual difficult part. So since it can't be avoided, embrace it and level up as a Blender user. Or more importantly, as a CG artist.
    6 loves
  • Borgelin replied
    Thanks, Kent.
    Your post provided a new perspective on how to approach this issue. I realize now that I've been tackling it in a somewhat backwards manner. Your logic has genuinely changed my viewpoint.
    But I'd also like to mention that in the last couple of days, I've started viewing new differences in the software as a challenge rather than getting frustrated trying to figure out the new way of doing things.
    • WAY TO GO! 💪👏
    4 loves
    Borgelin I'm so glad to read your response! Taking the software differences as a challenge instead of frustration - that's the attitude that guarantees success 👏
    The last thing I'll say: this "blender fluidity" perspective we're discussing applies to all Blender education, not just CGC's library. The resilience of your learning journey just took a big leap forward. Way to go!
    4 loves
  • Onar Hendison(lil) replied
    How can you tell what version the tutor is using
    2 loves
    llil whilst playing the video and Blender is in use by the instructor, the version is visible in the bottom right corner.
    2 loves
  • James Edafioka(stjames887) replied
    Totally understandable and you've received so much beautiful advice. I will also say don't be afraid explore. When I follow a tutorial, I follow twice or as many times as I can, that is to say, I follow using the native version that was taught (if I do have that version) and then I follow using the recent version. Or I just follow the lesson while figuring out how to do it in the recent version (it's fun dunno about you). Just my little piece. Happy Blending
  • Stella Mtnez replied
    While we all like courses to be updated I must say I still find value in courses made with 2.79 blender version, there are some gems hidden in older courses too and I still go back to look for some things sometimes, being said that updates are always welcome but do not discard value in older courses, I understand for beginners it is confusing but as one gets to know how to use blender also  gets to know how to associate concepts and what is where in newer versions, it is sad to see really good older courses gone just cause they are outdated and hehe new courses are always really nice to have
    2 loves
  • Jack B(jack___) replied
    I agree with not letting the Blender version limit what tutorials you learn from. Although I think that becomes a lot easier once you're at an intermediate level.
    As a beginner, when you're just keeping your head afloat with what's happening in the video, the small inconsistencies in shortcut keys or feature locations can bog you down a bit, wondering if you've stuffed something up. A pinned list of key changes, or even a wiki typed doc with the common 'gotchas' could be helpful. I think it's the same ones that tend to pop up a lot.
    Thanks again for all the great content
    3 loves
  • Huzaifa Amir(Huzaifa ) replied
    i'll also say once u learned! the basics atleast. it wont be hard for u to switch btw diff versions like on my pc 2.8 is more stable so only go to newest version when i want to use specific tools like or so geometry nodes and so.... Learning with the version used in tutorial will make ur life much easier.
    Happy learning
  • sheila5 replied
    It would help though if in the text of the course intro the blender version is mentioned. So people can decide if they want to follow that course and to start with the right version. Not every teacher has the opening screen included with the version.
    If something doesn't work i just google how it changed. For geometry nodes it sometimes is significantly different
    That issue with x or shift-x for switching colours has been an issue. Sometimes no combination at all seems to work
