The paper note stretches when I try to align in by size
Question Materials and Textures
The paper note stretches when I try to align in by size. I tried adding separating the notes object in a single note and all of the Texture coordinates options, is there a way to avoid stretching.
  • Martin Bergwerf replied
    Try Unwrapping the 'paper'...it might be incorrectly Unwrapped.
  • Omar Domenech replied
    Yes as Martin says, because it might be the width and height of your texture resolution image is not correlation with the width and height of the UV island. Another way can be to make the image texture in the same proportions of the UV island from the paper.
  • Adrian Bellworthy replied
    Yes as Martin and Omar says, make sure the UV's are correct. Trying to adjust the mapping node scale and location is not going to work if the UV's are incorrect.
    When using the UV texture coordinates, the UV's need to be correctly aligned with the image in the UV editor.
    Also you may need to apply the scale, this can cause stretching if the scale is not correct.
  • Y M(Absurditas) replied
    Thank you, this was the problem. It looks good now
