Odd normals
Question Modeling
I am working on a Cubicity inspired Irish Pub, and am getting some odd normals from the mirror function. The roof is mirrored on both the x and y axes, and the modeled area does not have a problem...is there a way to fix this?_Pub-odd_normals.png
  • Omar Domenech replied
    That is very strange. Perhaps you have an extra object in the Outliner? Can you upload the file and share the link for us to take a look at it?
  • Martin Bergwerf replied
    Hi Kate KKateMcCSeattle ,
    That looks like some Geometry poking through...Select all the Meshes (maybe even Hiding the Roof) and then go into Edit Mode...then try to Select the red parts.
  • Kate McCormick(KateMcCSeattle) replied
    How do I upload the file? I cannot select the red faces because they are generated by the mirror modifier. The problemexists even when I have everything but the roof hidden, so I don't think anything is poking through.
    Here is a screen shot showing just the roof:screen_shot.jpg
    You can upload your file to Google Drive or some other hosting service and copy paste the link here.
    Solution
    I think it might have to do with the Solidify Modifier.
    Here is the link: https://www.dropbox.com/scl/fi/98mts6lnl07glf2tgsidg/Irish_Pub.blend?rlkey=ru3bygrtszops0lqwq0ijyf5x&dl=0.
    Solution
    HI Kate,
    You should connect these two Vertices:Roof_01.png
    (with J).
    Thank you!!! connecting the vertices worked.
    Another good old mystery solved, Sherlock.
