Cartridge image texture pink in cycles
I got through the tutorial fine until I switched to cycles and the image texture became pink. I assumed I moved the file and I needed to relink it but it seems only to show the pink when in cycles rendered. When in EVEE, solid and material previews it's fine.
  • Martin Bergwerf replied
    Hi Emmanuelle eemmthebest2 ,
    That is a bit weird...
    Can you show us a screenshot of when that happens (full UI, Shader Editor open, Node Tree completely visible) using Cycles, please.
  • Omar Domenech replied
    That is for sure very weird, maybe even better than screenshots would be a screen recording.
