Can i somehow setup the world lights again?
Technically after i clearly made my mind to not make so warm the lights like in the reference photo i still wanted to add some . not that much but a bit less. Sadly i had to realize that i absolutely doesnt understand the world lights and how its set up . no suprise i managed to completly ruined it , so now i got no proper lights anymore . Is there way to set it up like the original was?
Reply
  • Omar Domenech replied
    Solution
    Yes, you can download the original file, create a collection called "Append" and in there put all the stuff you want to append. Then in your file, go to file -> append and append that collection to your file. Be sure to have the 3D cursor in the center of the world so that the stuff that comes in will be aligned properly.
  • raspora replied
    thank you , i did manage to send the sun position . but overall it doesnt give it back.
  • raspora replied
  • raspora replied
    in this surface place the original file got a huuuuuuge amount of stuffs. mine is total empty
  • Martin Bergwerf replied
    Solution
    Hi Csüllög,
    If I understand it correctly, you Appended the World Lighting, that means, it is now available in your File...
    But you haven't told blender yet to use that Lighting.
    If you click the down arrow here:
    you should see it and be able to select that imported (Appended) World Lighting.
  • raspora replied
    i could see if i can append it to my project. the good question is how do i do that? i dont find that on the object list.
    Solution
    Go to File > Append and then to where you have the original .blend and select the World:
    Solution
    This is how it looks, one step back:
  • raspora replied
    Thank you so much . it did worked.
