Tool icons from the Toolbar have disappeared
posted to: Selecting Objects
While working on a project the tool icons have vanished from the toolbar.  Hitting the T key toggles the toolbar (I can see the little arrow toggle) but no tools appear in the menu.  Any ideas on what may have happened would be greatly appreciated.  This is also affecting the right hand toolbar when the N key is pressed.
Reply
  • Martin Bergwerf replied
    Hi Gary ggnorwalt ,
    That is weird...I never heard that one before...
    Try File > Defaults > Load Factory Settings.
    If the problem persists, then you might need to update your drivers (especially the GPU).
    If the problem goes away when using Factory Settings, it might be a 3rd party Addon that is misbehaving.
    It could also be, that you accidentally changed some setting somewhere, but I wouldn't know how or which setting that would be.
    Can you access them from the View dropdown menu?
    ...or did you maybe change your Keymap in your Preferences to Industry Compatibel?
  • Adrian Bellworthy replied
    ggnorwalt have installed any addons recently?
    Some third party addons are notorious for this type of issue.
  • Omar Domenech replied
    Or the nuclear option, I'd download a fresh copy of Blender and install it from scratch.
  • Gary Norwalt(gnorwalt) replied
    Thank you for so many quick responses.  I will try these ideas (very interested in the GPU idea since it has caused issues before) and will update you on how they work.  I can get the icons back simply enough by starting a new project but reopening the old blender files takes me right back to the problem.  The workaround so far seems to be to go back and append the old meshes and material to a new blank file.
    Update - PROBLEM SOLVED -  I tried all your suggestions with no luck, thank you all for your help.  I was about to go nuclear as Omar suggested which luckily led to me stumbling on the problem.  It turned out to be User error. The original file was created using Blender 4.0.  When I opened the file again on the next day the computer opened it in Blender 3.6 without me noticing it.  Something about the version differences caused the tool icons to vanish.  Opening the file again in Blender 4 restores everything.
    Thanks for the update Gary!
    I will have to remember that this can happen 🗒️
    Blender being Blender, or computer being computers. Skynet will never happen.
