Linking Different Shapes in Blender ?
Hi, I'm new here :))  Is it possible to link two different shaped objects in Blender, like a cone and a cube, without duplicating them? I wonder if parenting is the only way or if there are alternative methods to link objects for shared properties or control. Thanks for any advice!
2 loves
Reply
  • Martin Bergwerf replied
    Hi Savvina SSavvina ,
    CTRL+L will open up a Link Menu where you can choose things that you want to Link.
    The Linking works from the Active (last selected) Object to the other Selected Objects.
    2 loves
  • Adrian Bellworthy replied
    Instead of using SHIFT+D to duplicate the object(s)...
    Use ALT+D, this will duplicate the object(s), however the duplicates will share the same data properties.
    2 loves
  • Omar Domenech replied
    2 loves
