Carve tool isse
posted to: Rough Sculpting
I created a new brush but I'm not getting the same effect. When I use it with Sculpt Plane set to "View Plane", it creates a crease in the position of the centre of the brush, and it affects the rest of the mesh instead of just the side I'm working on. Any idea of what may be causing this issue?
Reply
  • Martin Bergwerf replied
    Hi mmissigno ,
    I am having trouble visualizing what you describe; could you post a screenshot of your UI?
  • missigno replied
    Hi Martin, thanks for the quick reply. This is how I have it configured.
    Hi mmissigno ,
    Ah, so your using a modern Blender: that shouldn't matter, if you're comfortable with that.
    But I am missing most of your Settings (you only show that you are using View Plane, but we already knew that 😉
    Seriously though; I have no idea what could be causing that.
    Maybe you can post a link to your .blend file here (via GoogleDrive, Dropbox, or so), then we can do some troubleshooting...it might be something simple, but I don't know how to reproduce it...(maybe a more experienced Blender sculptor knows...)
  • Omar Domenech replied
    Yeah this is a hard one to visualize. It would be great if you can make a screen recording video so we can see the problem in action. This is an older course and Blender has changed a lot, it is possible that setting up the brush to produce the desired behavior has changed a lot.
