how can i hide my axis color?
posted to: Outlining the Shape
when i do the 6:43 part. where i need to blindly cut . i cant modify properly cuz i dont see the orange part with the Dots. (ofc its allready hard cuz i got no numpad to jump view without using the mouse but) i see a strong Y green axis line ( when i order the scale to go on it. can i ask how to turn it off for now so when i press S then any YXZ then colors doesnt pop up.
2 loves
Reply
  • Martin Bergwerf replied
    Sorry Csüllög raspora ,
    but I do not understand what you mean exactly...
    But maybe this helps: changing the viewpoint to front top, etc. Orthographic, without a Numpad can be done by ALT+MMB dragging up, down, left and right...
    It is good practice to always look at your model from all sides and not only from Orthographic views, so switching should be easy and natural...
    2 loves
  • raspora replied
    Wow thanks! now that is something i didnt know. thankfully tomorrow my new keyboard arrive. then it will be good. soo
    https://imgur.com/a/XUuYZVW
    heres an image . when i am on a flat position where i only can scale - based on the dots i see which is orange. BUT when i press X or Y to make sure the cuts are still stay on the surface. the color of the asked axis appears and cover the  orange dots.
    Is it possible to turn off the color of the red green blue axis , so when i press one of it it doesnt appear for a visual representation? ( sorry for struggle with the question my English is not that great.
  • Omar Domenech replied
    I don't think that can be done, at least I've never tired it. Though I can't see why that would be a bad thing to have the axis constraint visualization, I think you just have to get used to it.
  • raspora replied
    then i dunno
    https://imgur.com/a/75AAdhd
    in the video at 6:45 he say press S and X ( so its axis locked. )  and he still see the orange dots. while i am SOOO covered with the red color i cant even realize where the orange dots are.
    Solution
    Okay, I see what you mean now.
    You cannot (as far as I know) disable the constraint Axis Overlay. You can however increase the display size of your Vertices, which will make it easier to see them, even when the transform Axis is shown:
    It's in your Preferences under Themes, 3D Viewport. The default is 2 pixels.
    And also, while you are Scaling, you can use that same  ALT+MMB to look around your model, which might also help to see things better.
    2 loves
  • raspora replied
    Thank you So much ! i bumped it from 3 to 4 and now its much better . :)
