If i think that this could be made like. collapse the cube into its origin dot. and from the origin dort. start Extrude around the front edge. bevel corners , etc. then pull the whole stuff out from a flat plane to a 3d object?
i mean i dont have issue about this but i wonder if i do this a different way than this than its an okay thing to do or it has a proper meaning of doing it like this.
Yes, there are many, many ways of doing this and all are valid, as long as they get the result you want.
It's more of a preference than suggesting that one way is better than another. The result is what counts most, not so much how you get there.
2 loves
replied
Solution
Yes exactly, there are a lot of ways to accomplish the same thing, though if you're a beginner and planning to follow along with the video, maybe you should do what I do, just watch the course as if it was a movie and then you co in a second time but this time hands on and going after a good final result but now having an overview of it all.
Thank you for the answers. ill keep copy the video as close as possible . before i try to extend my process of doing the same thing in a whole different way.
