Bevel Problem
posted to: Outlining the Shape
Around 2:09 he beigns to bevel the corner of top corner of the console. When I try to bevel the two corners the tool activates but has no effect I have started over a few times and the problem persists. I am brand new and can not seem to figure it out.  I did apply the scale.
2 loves
Reply
  • Martin Bergwerf replied
    Hi Alexis aalexispb310 ,
    First do a 'clean up', because your failed attempts might have created some so-called double Vertices; Select all Vertices (with A) and then M > Merge > By Distance.
    Then make sure you have all 4 Vertices Selected:
    and CTRL+B to Bevel.
    If that doesn't help, let us know, please.
    2 loves
  • Adrian Bellworthy replied
    TOP TIP:
    Use edge select when selecting multiple edges to bevel.
    Bevel is an edge tool, vertex select can sometimes mean unwanted edges can also be selected.
  • Omar Domenech replied
    Another tip is when you select the edges or vertices, tap G and move them around, you'll see instantly if there is something wrong if they behave weirdly or you have double vertices.
  • Alexis Badillo(alexispb310) replied
    I Figured it out after taking a break last night the trick was to merge by distance. Thanks alot guys.
