Elastic f-curve parameters not doing anything
Hi everyone,
I am preparing my looping pattern project.
I use an elastic interpolation on a curve controlling the distortion parameter of a texture :
But for some reason, the "Amplitude" parameter does not change the height of my curve. The period parameter is not working either. Any idea why ? 🤔
Reply
  • Martin Bergwerf replied
    Hi koala,
    No, I don't know why it isn't working. What is your Node setup? It seems to work fine here:
  • Koala replied
    Node setup :
    The parameter on which i wanted to apply an elastic curve is the distortion of the second wave texture
    (the horizontal scrolling has its own linear f-curve)
    Solution
    Oh, I think I know:
    You have the second Keyframe of the interpolation selected (80). Try selecting the first and change the Amplitude there...
    2 loves
  • Omar Domenech replied
    That is it most likely. Took my a while to get used to the modifiers in the curve, they always disappeared and I had constantly remind myself that I needed to have a desired keyframes selected. You get used to it.
    2 loves
  • Koala replied
    It worked ! Thank you.
  • Adrian Bellworthy replied
    If I remember correctly, most of the modifiers in the graph editor take effect from the keyframe onwards, leaving the anything prior to the selected keyframe unaffected.
    So with only start and end keyframes, adding to the end keyframe nothing will happen.
