A problem
posted to: Outlining the Shape
Hello! I have a problem at 6:56. When I try to use the Bevel function, the shape is not smoothed, but a new one appears
    Without seeing an image it's hard to say. So, default trouble shooting steps it is. Select object, tab into edit mode, press A to select all, Press M->By distance(This removes any duplicated vertices. Then Shift+n to calculate normals to outside. now retry your bevel. If it's still not smooth. just left click, then expand last operation box(Bottom left hand corner of viewport window. It should say bevel on it.) Then make sure that the Shape setting is at 0.5.
  • Omar Domenech replied
    Yes, expand a little more on the problem and use screenshots to visually support it, so it's easier to diagnose what is going on.
