Issues with limited beveling
When i try to bevel these cuts at the back the bevel modifier doesnt do anything and it seems like it is limited and since clamp overlap is off i dont know what causing it
Reply
  • Nikolay Gofman(Kolyasko) replied
    2 loves
  • Omar Domenech replied
    Solution
    Check if you have your scale applied to your model. Also check if you have double vertices, select everything and M to merge by distance.
    2 loves
    Merging actually helped, i dont even know how thece vertices got there. But thank you very much!
    2 loves
