Delete Faces
Hi :), I'm trying to delete the faces to make room for the speakers, one of them works perfectly but when I delete the other one also other faces get deleted with it.
Reply
  • Omar Domenech replied
    Hello. Can you upload some screenshots? Most likely you have some big faces that are not connected and you need to connect them with J to make a face so the shape holds up. Kinda hard to explain by text but with some visual reference it will be easier for us to figure out what is going on.
  • Rosy Pallone(Rosy) replied
    Thank you so much for your help and sorry for my late reply. In the first picture I deleted one face and as you can see it works perfectly 1-31 at 16.21.01.png
    But when i delete the other one, this happens
    This is the face i should delete
  • Martin Bergwerf replied
    Oh, Rosy RRosy , I actually can't tell from the screenshots...
    You probably made a mistake when Filling those Faces earlier...
    If you can post a link to your .blend (upload it to Dropbox, GoogleDrive, or so), we might be able to pinpoint the exact thing(s) that go wrong.
    Sure, thank you so much, here's the Google Drive
    Hey Rosy,
    That's the .blend1 file, (that is sort of a backup) and that doesn't seem to be up to date with your problem version.
    I had to Add a few Edges, but then those two Faces could both be Deleted without any problem:
    I'm so sorry, I'm new to Blender and I think I should've sent you this file instead:  .blend
    Yep, that's the one, thank you!
    So, the problem is actually the Bevel Modifier: disable Clamp Overlap and all is fine:
    THANK YOU VERY MUCH, THIS COMMUNITY IS AMAZING!!!
