Dynamic Paint Not Rendering
I am making waves using dynamic paint with the duck as the brush and the water as the canvas. It works perfectly in the viewport, however there is no displacement in renders. I also try to bake all dynamics, however, that makes it stop working in both in the viewport and render. Trying to render Cycles. Can anyone see what I am doing wrong?
Viewport Render:
Render Image:
Settings:
Reply
  • Martin Bergwerf replied
    Hi Shannon ttreecalledgroot ,
    Make sure, that in your Output (DP Canvas Settings), the Paintmap Layer is not red; if it is red, you need to click the plus on the right:
    There might also be something wrong with the Geometry Nodes setup, but there is no way for me to tell from just the screenshots.
    If you want to post a link to your .blend file, we can see if we can find the culprit.
  • Shannon (treecalledgroot) replied
    Hi Martin,
    Thank you so much for your help.
    Here is the Blend File
    Oh, you can see how long it's been since I used Dynamic Paint...Those Paintmaps are not there, when using Waves...
    But that aside, I honestly don't get a different result between Render and Viewport, when I disable Motion Blur:
    With a bit more extreme displacement and using Rolling Shutter in the Motion Blur:
    Sorry Sahnnon, forgot to tag you ttreecalledgroot ,
    Did this help, or are you still having issues?
    ...Actually, let me come back on that; it's not the Motion Blur that's causing it. Here's when I re-opened your .blend, without changing anything, just pressed F12:
    So my guess now is, that it somehow has to do with Caching...First time I opened your file, I didn't have anything cached, but now I have a blendcache_Rain sitting next to the .blend...
     I really appreciate your time and effort on this.  I also now think it's my cache.
    After I bake it, it just freezes the whole simulation, even on the viewport.  It also still says 0 frames on disk.  This is when I do bake or bake all dynamics
    Try it without Baking..just play the Animation before Rendering (and Render individual Frames, of course)...
    Maybe this:
    Set the Start Frame in the Timeline to 1. Bake the Simulation. Change the Start Frame to 80 and Render.
    Seems to work fine:
    I'd Delete that Cache Folder, just to be sure, before Baking.
    Neither works unfortunately
    I just appended everything into a new scene and it worked.  Weird!  Thanks again for your time and effort. Much appreciated
  • Omar Domenech replied
    You see, that's the solution I'm always proposing, I'm glad to see it does work for someone besides me.
    2 loves
