Non-existent edges appearing upon shading smooth(auto-smooth)
When the shading is flat these edges do not appear but when shaded smooth with auto-smooth they appear when I go over 22 degrees, how doo I fix this?
https://imgur.com/a/AXRAzF6
Reply
  • Adrian Bellworthy replied
    Solution
    It's probably because the vertices on the flat surface are not... well... flat
    In edit mode and side view, box select the vertices that make up the flat surface and press S 0
    Another issue could be the angle of the indent for the buttons and screen
    Pushing the extruded vertices down a little more will increase the angle.
    2 loves
  • Martin Bergwerf replied
    Keep the Auto Smooth Angle below 22°.
    You could also try to lower the inset Edges around the buttons a bit on the Z-Axis..I mean these:
  • Omar Domenech replied
    And just because well why not since it always happens, see if you have double vertices, select all and M to merge by distance.
  • Negetive 0(Negetive0) replied
    Turns out that the angle of the screen indent was too little and I just had to lower the extruded vertices a bit.
