Reset Primitive Creation Parameters to Default
I added primitives and changed their settings using the last operation panel to try and recreate the shapes from the video. However, now every time I add a new primitive the settings are not the default values. This means that when I add a UV sphere for example it comes out looking more like a pyramid. I found an option at the top of the panel when creating a torus to "restore operator defaults" which worked but can't seem to find it for the other primitives.
Reply
    Solution
    yes, blender remembers the last settings you set until you start a new session. You can restore to default by right clicking on each setting and clicking restore default. A quicker method if you have multiple fields you need to reset is to click in the top one press delete so there is nothing in the field and then press tab. hit delete and tab for the fields you want to reset and just press tab on the fields you want to leave alone.
  • Harry Jones(harry4) replied
    Thank you for explaining that! Hitting tab and delete works fine for me :)
