Hello. I was following a video and creating a fill. I've done the bottom part and the top but the middle is doing something weird.
I'll try and attach an image.
Hi
Agata ,
The problem is because you are using Vertex Select Mode, some Edges (and Faces) that you don't want Selected, are also Selected, for instance:
You need to make your Selection in Edge Select Mode. Then try again.
I always say that Press Start is not super duper beginner friendly. If you want to control topology much better there's the Modeling boot camp:
Thank you Martin! That worked.
And Omar, thank you for the course suggestion. Itβs in my playlist now )
