Why didn’t you add an image plane into the viewport?
I would have thought being able to model directly over the image would have helped a lot and it’s a pretty basic workflow step. Why did you omit this here?
  • Martin Bergwerf replied
    You can do that if you want to, but with the concept art not being in orthographic views, it might be easier this way.
    But I suggest you try it, maybe it is easier for you with the image it the Viewport.
  • Adrian Bellworthy replied
    Exactly like Spikey said.
    If there was a reference for each view (front, side, etc.) then your approach would certainly be the right way.
    There are many things in Blender and 3d in general, that are not necessarily right or wrong, but a different approach.
    If you are new to Blender, you may have seen other courses/tutorials using a different approach, keep in mind every technique can't be taught in one course, unless the course was hundreds of hours of video.
