Not able to fix scaling like the rivet fix
posted to: Laying Out UVs
Hello, I noticed a plank that's sharing data with 2 others had the same issue as the rivet in the video where the scale was already applied but its texture wasn't evenly spaced like the others. After moving the source plank to the UV folder, and averaging the islands scale, it didn't fix the issue. The plank is still far larger than the others. I'm not sure how to fix this.
  • Martin Bergwerf replied
    Hi vvioletcrystal ,
    That sounds like a matter of Scale not being Applied somewhere...
    If you can't figure it out, could you please post a link to your .blend?
  • Omar Domenech replied
    You can also manually scale down the plank UV to fit with the others, nothing wrong with that I suppose.
