I submitted this final assignment earlier.
I learned a lot from this course. I hope they make more...8^]
https://sketchfab.com/3d-models/roboorb-topology-sketchfab-c6ef5e8891af42aa9a01036eb5084c80
Hi Brad, I'd like to see it without the Subdivision Surface Modifier..
It's not bad, but you have 6-sided Poles here (and symmetrically on the other side):
and even 7-sided ones here:
But I must admit, that those poles are not noticeable in the rendered version (not even with a shiny Matcap), so: good job 👍🏻
Wow, great points. I swapped out the models and you can view it with no sub d now. I'll swap it back later.
Thanks for your eagle eye assessment, I missed that altogether
Yeah, that 6 sided at the back of the top portion was from the course instruction so the poles seemed to let slide at this level, I think, but you're right and something to be mindful of, as well as smoothing out the spacing better. The shetchFab wireframe is great for checking things out.
Thanks
Very good points Martin. I updated the SketchFab to reflect and remind me what to be mindful of.
Thanks
