FIRST ABSTRACT PATTERN
I dont understand what you are doing for changing axis of each layers of the array.
  • spikeyxxx replied
    I am really sorry, but I do not understand what you don't understand about the Array axes.
    (You are probably talking about the First Pattern as in your question title...the second doesn't use an Array Modifier).
  • Omar Domenech replied
    Hello Olivier. Yes if you could explain more and add more context to your question so we can help out. Perhaps add a screenshot or two.
  • Adrian Bellworthy replied
    Hey oolivierduchossoir,
    In the array modifier, change the factor to 1, in the axis you want the array to work.
    i.e. Constant offset only enabled - X = 0, Y = 0, Z = 1, this will array  the model in the Z direction by 1 meter, as in the lesson.
    Have a play with the array values to get an idea of what it does.
    Hope this helps!
That course doesn't exist!
