Setting up drivers
Video Time - 8:51
After I select 'Single Property", then Prop: Armature.....Next I right click on Path which brings up a Data Path dropdown. I attempt to choose Copy Data Path but all three choices are not active,  not even the shortcut works: Shift  Ctrl C
is there another way to accomplish this?  I have Blender 3.1
Maybe the short way?....I will see when I get to that.
Patty Hatfield
  • Martin Bergwerf replied
    Hi Patty B. ppattybhat ,
    You need to right click on the Custom Property (in the 3D View) and select Copy Data Path. Then hover over the Path (in the Driver Editor) and CTRL+V to paste that Data Path there. Right-clicking on the (red) Path field doesn't show Copy Data Path, because there is no Data Path yet to copy.
    I tried this method in 3.1 and it works like in the video (apart from a slight change in editing the Custom Property, but you're already past that).
    • Thanks Spikey
  • pattybhat replied
    Thanks!
