Hi there, When choosing a background image as environment texture it lights the scene as intended. However, the image its...
posted to: World Environment
Hi there, When choosing a background image as environment texture it lights the scene as intended. However, the image itself is not shown in the 3d view (as seen in the video). So i jumped into the properties panel, ticked the World Background box under display, and now it's shown in solid mode. But...it still isn't visible when using the Rendered view (cycles). I'm probably missing a tickbox. Can you tell me where I can activate it? cheers. Edwin
  • Kent Trammell replied
    Go to your render settings and look in the Film section. If you have Transparent checked then the world environment won't be visible in the camera but it will contribute to the scene's lighting.
  • Matthew Fricker(frikkr) replied
    I had the exact same problem, and my transparency wasn't checked as Kent suggested but I hit Numpad 5 to toggle orthographic view and it came up. Seems it wont display the background when you are in orthographic.....
  • Edwin Klijn(edlunchiemunchies) replied
    Got it! thx
    Transparency wasn't checked. I must have missed it in the tutorial. Thx
