No "Available" keyframe option
What should I select for keyframe if there is no "available" option for setting a keyframe in my menu? I'm on Blender 3.3.0.
  • violetcrystal replied
    Interesting, I pressed "I" key twice, and the "Available" option showed up. Why does that happen?
  • Martin Bergwerf replied
    That is normal behavior and nothing new; this also happened in the days before 2.80. By pressing I twice, you set a Keyframe. If there are no Keyframes, Blender doesn't know what to use as Available....
    Curiously enough, even without any Keyframes, you can select Available as the Keying Set in the Timeline (probably a bug/oversight):
    but Blender will throw an Error ("No suitable context info for active keying set"), when you then actually try to use that by hitting I.
  • Omar Domenech replied
    Yeah I think basically you first need to have a keyframe in so Blender knows there is stuff available there so you can use the "Available" option. I never use that, maybe I'm getting grumpy and old and I like to do things manually and I insert keyframes with "I" all the time.
No profile found
