uv texture
Hi,
Guys i have a question, why in the 3 area the uv texture are face to the other direction,
 but the left and middle side quad are fine.
  • Omar Domenech replied
    Hello Senyr.
    Probably your face normals are flipped. You can recalculate them with Shift + N
    You can see where your normals are pointing here:
    Also if you turn on Face Orientation you can see if you have a face with a flipped normal:
  • Martin Bergwerf replied
    Hi ssenyr ,
    I am sorry, but I do not understand your question.
  • senyr replied
    thank you Omar for you answer 🤩, I thought that was it but it remained the same😭
    Martin, Is there a possibility that the texture will be similar within the quad
    Because in quad number 1 and 2 they show the same texture but quad number 3 it shows a blacker texture but behind it , it shows the same texture of number 1 and 2
    Oh, that is probably because of the lighting; more light is coming from the right than from the left, therefore one side looks lighter than the other.
  • senyr replied
    Thank you Martin,
    it works😀
    • Great!
    Well I'm glad it was even simpler than that.
No profile found
