Modelling a mess of lines for an architectural building?
I have this architectural model to build and before I leap into it, I was wondering if you had any great ideas to make the random lines of this appear over the outer walls?
http://www.nemesistudio.it/en/projects/type/culture/item/714-italy-pavilion-expo-2015-milan.html
It will be for a low poly model (ie in a game environment), so I was thinking of modelling the basic shape of the walls (eg a curved box basically) and then modelling the main lines on top (with Shrinkwrap) but making the smaller lines as a transparent png. Just keeping in mind I'm trying to make this as low in poly count as possible.
Any better ideas?
Thanks in advance.
  • adrian replied
    I think your approach would probably work best, a texture with alpha transparency. Keeping it low poly as needed.
