Hey there,
this should be the simplest job, I’m superimposing some bifold glass doors over a photo. But for some reason when I view in the viewport, and then render, then the reflections look right, but when I import into Affinity Photo it looks like it’s missing the reflection of the clouds. Can anyone explain why?
Blender file is here…
https://drive.google.com/file/d/1ZhnQT6fpmhaE9eA3jkO6wy_CB5NL0m4j/view?usp=sharing
Hey Ross,
I'm not an Affinity user, so I can't help you there,
When you render the image in Blender,
I assume you are saving the render with a new name, other than the original image name,
and import the new image into Affinity?
Hey Adrian, yeah I am.
Another Blender user is saying...
"Keep in mind that Blender is using a linear workflow. For a correct result in Photoshop (or Affinity Photo), you need to set the composition to 32bit. Same for After Effects. In AFX you can set the composition to "Linearized Working Space" to get a proper color transformed result.
