I have a blurry screen in my rocket ship flying ?
Collaborations
I have 3.0 I have a blurry view when the ship and camera move. How do I fix this?
  • adrian replied
    Hey Edward,
    can you be a bit more specific on the issue you have, perhaps a screen shot or a link to the file via google drive, dropbox or similar.
    Is this happening when you preview the animation in the 3d viewport in rendered viewport shading?
    If so make sure you have Eevee selected in the render properties and not cycles.
  • edward13 replied
    HAHAHA THANK YOU
    one was on cycle and one was on eevee
  • edward13 replied
    And in cycle  it is blurry
  • edward13 replied
    Okay how do I do a screen shot with the computer
  • edward13 replied
    I will do it over
    It will take me half the time
  • adrian replied
    I use SHIFT+CTRL+I to save a screen shot, but that is the hotkey combination set via my GPU.
    You can render the 3d viewport without a camera and lighting,
    Click the VIEW menu at the top left of the 3d viewport and select viewport render image, when its done, click image and save or save as.
  • adrian replied
    Each frame of the animation is one image, 24 frames = 24 images.
    Its blurry because cycles can't render each image quick enough before the next frame of the animation.
  • adrian replied
    This course is designed to use Eevee rather than Cycles.
    Using rendered viewport shading with Cycles is good for viewing a single image or frame, but not viewing an animation.
    If you are using Cycles for a project then material preview mode will play the animation without the blur, this mode essentially uses Eevee for the viewport even when Cycles is selected.
  • edward13 replied
    I have notes there are thing not in 3.0 and then the others also I see thing have been moved or added on
  • spikeyxxx replied
    3.0 uses CyclesX, a complete re-write of the Cycles code.
    The Settings panel looks a lot different, but the default settings should be fine for this project.
    Btw. for taking Screenshots there is a lot of software available. I mostly use Flameshot: https://flameshot.org/
    on Linux, but it is also available for Windows and Mac....and it is free and  Open Source!
  • edward13 replied
    Thank you will try. i was thinking of trying it again or mass with the camera
