SOLVED: Pothead Tutoriall: Help UV Unwrap keeps exploding
Collaborations
Link to Blend file
OK I am home sick with COVID, and feel like I am losing my mind. I have been working on Pothead for about 3 weeks now. I FINALLY got to the UV Unwrap and realized I had one seam wrong. So I selected the seam and unmarked it, but it stayed on the grid. So I selected all the seams and unwrapped them. Then selected the entire pot and selected Reset.
That is when everything broke. Of course I have saved it right as everything fell apart and not a clean UV free version.
Now when I try to make any seam and unwrap it literally blows up. Now I have spent hours randomly clicking on things and it is only getting worse. Here are 3 consecutive pictures. Me clearing the seams. Unwrapping. Putting in a new seam and EXPLOSION.
At the top is the link to my file. I really don't want to start over on this one. Is there a way to go in and delete any UV stuff from the file?
Thanks,
Ang
  • spikeyxxx replied
    That is very annoying, to say the least.
    First of al, make sure that Correct Face Attributes is un-checked (might mess things up and is an easy step):
    But my (wild) guess is, that it is your Data Transfer Modifier that is messing things up.
    Try deleting it together with your duplicated Mesh, fix your Unwrap duplicate the half of your Mesh again and add re-add the Modifier.
    If this doesn't help and @jlampel also has no idea, maybe post a link to your .blend file (via Googledrive or Dropbox or something like that), so that we can have a look (there are many good troubleshooters in this community!)
  • Ang Deaver(shegeek) replied
    My blend file is at the top of my post. I’m off to bed but will try your suggestion when I wake up thank you.
  • spikeyxxx replied
    Oops, missed that;)
    Good night and good recovery.
  • spikeyxxx replied
    Found it!
    You have Pinned Vertices.
    In the UV Editor select everything and then ALT+P to un-pin all the Verts.
    Then unwrap again.
  • adrian replied
    Good find spikeyxxx ,
    Spikey you rock!!!!!  Thank you so much.
    cyber-germ-free hugs
    //happy dance
    Ang
    Thank you - it now works perfectly. I doubt I will forget how to fix this one again :D
  • Jonathan Lampel replied
    Yay, glad that worked out! Haha I think forgetting and re-learning is definitely part of the process. Good luck with the rest of the course!
